123martinh's avatar
123martinh
Follower
Jan 10, 2022
AC1200 Dual Band WiFi Range Extender
I am posting a solved problem to help others:
On installing this new Dual Band Wifi Extender using WPS the _2GEXT configuration rejected the router password.
The (same) password worked and connected on the _5GEXT configuration.
(In the location I need this extender for I needed the _2GEXT to work.)
Reset and remap via WPS and trying to connect a variety of devices to the _2GEXT.  consistently rejected the router password
After the second reset I tried to install via the NETGEAR_EXT local wifi
As a heads up to other purchasers of this product I could not connect into this using Mozilla Firefox, it needed Michrosoft Edge.
Manual input loaded the  _2EXT password successfully, likewise the _5GEXT.
Problem solved!
Cheers
Martin H
1 Reply
  • plemans's avatar
    Fairly common to use the installation assistant and not WPS for setup. Sadly, a lot of isp supplied routers don't code wps properly and it causes issues.
    But glad to hear you got it working!
    thanks for posting this
