Relean
May 05, 2020Aspirant
AC1200 EX6150v2 extender
I recently purchased a AC1200 EXTENDER - I have set up the extender according to instructions, have all the green lights, and the extender shows on all devices that connect to the internet. When I move the extender to a location that will benefit all the devices in the house I have no internet connection on any of these devices. How do I get the extender to recognise my internet or get the devices online with the extender?
The problem with extenders is that they need a good signal to function.
so if you're moving it to an area where devices don't have signal, neither will the extender.
Optimum placement is halfway in between where you want signal and where you have signal. Provided that's a good signal area.
Another issue is thatt many things can block wifi signals. this includes hvac in walls, concrete/brick walls, foil insulation, adobe, plaster lathe, etc.
What are your interior walls made of?
How large is your home?
What router is it connecting to? This is key to as the router is the backbone of the system. If the router isn't decent, the extender won't function well either as its relying on the router.
- ReleanAspirantThanks for the reply - even keeping the extender in the same room leads to no internet, though don't have any of the things you listed that might impede the signals. I have kind of given up trying to fix it - very frustrating!
Relean wrote:
Thanks for the reply - even keeping the extender in the same room leads to no internet, though don't have any of the things you listed that might impede the signals. I have kind of given up trying to fix it - very frustrating!What router are you using?
What firmware is on the extender?
