fredduke
Nov 15, 2016Aspirant
AC1200 Netgear to netgear Nighthawk Ex7300
I have the AC1200 Netgear installed and I want to replace it with the Nighthawk do I have to delete the AC1200 before I install the Nighthawk?
- Nov 18, 2016
Hello fredduke
If you are just replacing it then no your just need to setup the new Nighthawk Ex7300.
DarrenM
DarrenM
Nov 17, 2016Sr. NETGEAR Moderator
Hello fredduke
You would have to factory reset the extender if you are adding a new router.
DarrenM
fredduke
Nov 17, 2016Aspirant
Maybe I did not clearly ask the question, I want to replace the AC1200 with the Nighthawk. I am a novice at this computer stuff so I am not sure what you mean by doing a reset. Could please explain what a reset is. Thanks
- DarrenMNov 18, 2016Sr. NETGEAR Moderator
Hello fredduke
DarrenM
