kylieharriman
Jul 11, 2016Aspirant
AC1200 range extender taking over wifi network
My AC1200 easily connects to my wifi network and the signal strength is very good. Unfortunately within a few hours of connecting the extender all devices connected are kicked off the wifi and (altho...
DarrenM
Jul 14, 2016Sr. NETGEAR Moderator
Hello Kylieharriman
I would make sure you have the latest firmware for both your extender and router and you may want to adjust the wireless channel on your router to get the best possible signal.
DarrenM
- kylieharrimanJul 20, 2016Aspirant
Thanks for the response. How would I do both those things?
- DarrenMJul 21, 2016Sr. NETGEAR Moderator
Hello kylieharriman
Here are a couple links to help you out
http://kb.netgear.com/app/answers/detail/a_id/1027?cid=wmt_netgear_organic
https://www.netgear.com/support/product/EX6120.aspx?cid=wmt_netgear_organic#download
http://kb.netgear.com/app/answers/detail/a_id/23783?cid=wmt_netgear_organic
DarrenM
