PerPoet
Aug 18, 2018Initiate
ac1200 stuck on amber
My ac1200 has had severe problems right from the start. It kept on restarting itself quite frequently, so after having consulted this forum I thought it would be a good idea to download the latest so...
Aug 18, 2018Guru - Experienced User
PerPoet wrote:
The light starts to blick, but then it just goes back to steady amber.
Is this the Power LED, or one of the others?
If it is the Power LED, you might try a 30-30-30 reset. No guarantees it will work, but it is simple to try. It might be simpler to do with an extension cord.
- With the extender powered on, hold the reset button in for 30 seconds.
- Continue to hold the reset button in and unplug the extender, holding it in for another 30 seconds.
- Plug the extender back in, with the reset button still held, and continue to hold it in for another 30 seconds.
PerPoet wrote:
My ac1200 has had severe problems right from the start. It kept on restarting itself quite frequently ...
How long have you had it?
PerPoet
Aug 19, 2018Initiate
Thanks, but it did not work. Still stuck on amber. I've had it just a couple of weeks and it has never worked properly. Does anyone have a suggestion for a betterand more reliable brand of extenders? Thanks.
