SethOx
Nov 15, 2018Guide
AC1200 WiFi extender connection problem with password
Hi, this problem has already been posted and is marked as solved, but I don’t understand the solution (which was to access the UI of the router, find the IP address of the extender and find the passwo...
Nov 16, 2018Guru - Experienced User
Do you have a device you can connect to the EX6920's ethernet port? If you do, you can then browse to www.mywifiext.net.
Also, do you have any non-apple devices that you can try to connect to the extender wifi network?
SethOx
Nov 19, 2018Guide
Hi,
Thanks for your advice, I connected my laptop to the extender using an ethernet cable and followed your instructions, and it worked. Thanks!
