knight49
Sep 15, 2018Follower
AC1200 Wifi extender EX6110
Purchased a NETGEAR WiFi extender EX6110. Struggling to set it up. Tried and completely failed to set up using WPS, did not work at all despite numerous attempts. Then tried manually via mywifiext, w...
Sep 17, 2018Guru - Experienced User
What channels is your router using?
You can register the extender at my.netgear.com (uploading your proof-of-purchase), and then open a support ticket.
Use_less
Nov 25, 2018Tutor
How do I upload my proof of purchase. Can’t seem to find anywhere
- StephenBNov 25, 2018Guru - Experienced User
You can check your registration at my.netgear.com, and from there you can upload your proof of purchase.
- Use_lessNov 25, 2018Tutor
Thanks for the answer but I couldn’t find where to upload. I have already registered
- StephenBNov 26, 2018Guru - Experienced User
Go to the registered product list on my.netgear.com and click on the product (EX6100). You should see a popup that will give you the registration details. That popup also has a link to upload the proof of purchase.
