Patrick00000
Jul 27, 2017Aspirant
AC1200 wifi extender
I recently bought this AC1200 wifi extender, got it setup, and upgraded the firmware to the latest version. I have it in my basement and then plugged into the ethernet port running it to my PS4. ...
DarrenM
Jul 28, 2017Sr. NETGEAR Moderator
Hello Patrick
You may want and change the wireless channel on your router could be something interfering with the connection.
DarrenM
Patrick00000
Jul 28, 2017Aspirant
Hello Darrren,
Thanks for responding.
Anything connected directly to the route has no issue, only items connected to the extender. I can be directly on my router on my cell and no disruption, however anything coneected to the extender loses connection and the extender has to has the power cycled inorder to work again.
I created a case for this issue and have had no response for over 48hr now.
Thanks,
PB
