pilsitz's avatar
pilsitz
AC1200 WiFi Range Extender, Model EX6150
I want to use this extender in Access Point Mode.  It was previously set up in Extender Mode.  I did a factory reset and connected it to my router with an ethernet cable.  It shows 2 networks:  NETGEAR_EXT and NETGEAR_5gEXT.  They are both OPEN networks.  I want to set them up with different names and passwords but when I connect to one and follow the setup instructions I get the message that I am not connected to the extender network.  When I log into my router it shows the extender details and under SSID is says n/a.  How can I rename the networks and add passwords?
      • plemans's avatar
        Where is it failing when you try that?
        Details are key. Just saying it doesn't work doesn't help because we aren't there to see what exactly you're doing/trying.
