BH926's avatar
BH926
Follower
Feb 07, 2017
AC1200 Wifi Range Extender Model EX6150v2 Troubleshooting After Power Outage
I had to Reset my Nighthawk R7000 after a power outage by unplugging it and plugging it back in.
What are the steps to get my Model EX6150v2 AC1200 Range Extender working again? Do I simply unplug it and plug it back in or is there anything else I should do?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello BH926
    You can try to replug it but if the extender still does not connect you may need to link it with WPS again or factory reset the unit by holding the reset button on the extender for 10 seconds then try the extender setup again.
    DarrenM
