ChrisJM
Nov 09, 2018Follower
AC1200 Wifi Range Extender not working!
So, I’m not sure if this si thw right board, but I’m having trouble with the Netgear Dual Gigabit wifi extender that’s currentely installed at my Grans house. It was working fine and as intended be...
Nov 09, 2018Guru - Experienced User
What extender model is this?
You can set it up without using WPS - just reset it, join the extender network, and browse to www.mywifiext.net.
Gods_Chancla
Jan 11, 2019Initiate
I'm having the EXACT same problem, but your suggestion doesn't hep. With or without pressing the WPS button on the extender, it only broadcasts the connection for a short amound of time. When I tried to connect to it, it says "Unavailabe to Connect", then the broadcast dissappears.
