KarlDM007
May 20, 2018Follower
AC1200 Wifi Range Extender Problem
I can only get WiFi reception half-way to the other side of the house with my NETGEAR17 Nighthawk DST Router R7300DST & DST Adapter DST6501 (NETGEAR17_EXT). What is next - run a landline ethernet fro...
DarrenM
May 21, 2018Sr. NETGEAR Moderator
You may need another DST adapter for the other side of your home to get the coverage that you are wanting.
DarrenM
