Freya1200's avatar
Freya1200
Follower
Aug 07, 2018
AC1200 Wifi Range Extender
I am having trouble connecting Apple devices to the Wifi extender and as it says in the instructions the wifi router password is the same as the extenders but when I go to connect it is says failed t...
  • DexterJB's avatar
    Aug 07, 2018
    Hi Freya1200,
    Welcome to the community!
    You can access the UI of your wireless router and find the IP address assigned to the extender and use that to get to the extender's UI. Once there, you will find the password.
    Dexter
    Community Team
