carmelahollin's avatar
Sep 21, 2022
AC1900 Dual Band WiFi Mesh Extender - model #: EX6400
I cannot get the wifi extender connected. I got it connected to my router but there is no option on devices to connect them to the wifi extender.
1 Reply
  • plemans's avatar
    1. what router did you connect it to?
    2. what firmware is on it?
    3. the EX6400 is a mesh extender. It uses the same ssid/password as the router so it won't show up as a different network. It allows your devices to roam between it and the router as needed. You can disable this function if you want.
