Riadcruz
Nov 15, 2018Follower
Ac1900 ex700 WiFi signal keeps dropping
My WiFi signal keeps dropping on my WiFi extender. I have Ethernet plugged into my ps4 and it will say lan cable not connected and I look at the router and the signal is off. The normal WiFi is fine b...
Nov 16, 2018Guru - Experienced User
What firmware are you running?
Many folks have had issues with 1.0.1.78. If you are using that, you should try downgrading to 1.0.0.66. https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
Perhaps also try unplugging and reinserting the ethernet cable. The EX7000 shouldn't disable the LAN port when the extender-router connection drops. So if this is happening there could be an intermittent issue with the cable or the NIC hardware (either in the PS4 or the extender).
- sherysakariaMay 14, 2019Aspirant
Hey,
I think I have the same problems after updating my firmware and now when I'm trying to downgrade the firmware it says " Firmware upgrade failed. Please check your file."
Please help as I live in a granny flat behind the main connection and it's very hard to survive without internet.Regards
