Riadcruz
Nov 15, 2018Follower
Ac1900 ex700 WiFi signal keeps dropping
My WiFi signal keeps dropping on my WiFi extender. I have Ethernet plugged into my ps4 and it will say lan cable not connected and I look at the router and the signal is off. The normal WiFi is fine b...
Nov 16, 2018Guru - Experienced User
What firmware are you running?
Many folks have had issues with 1.0.1.78. If you are using that, you should try downgrading to 1.0.0.66. https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
Perhaps also try unplugging and reinserting the ethernet cable. The EX7000 shouldn't disable the LAN port when the extender-router connection drops. So if this is happening there could be an intermittent issue with the cable or the NIC hardware (either in the PS4 or the extender).
sherysakaria
May 14, 2019Aspirant
Hey,
I think I have the same problems after updating my firmware and now when I'm trying to downgrade the firmware it says " Firmware upgrade failed. Please check your file."
Please help as I live in a granny flat behind the main connection and it's very hard to survive without internet.
Regards
