PurpleNurple9
Aug 01, 2025Aspirant
AC1900 extender connection problem
My old AC1900 and AC1200 extenders will not allow my WiFi devices to connect, after CenturyLink installed a new modem router: C4000BZ. I am able to get the extenders connected to the CenturyLink, but...
PurpleNurple9
Aug 03, 2025Aspirant
Thanks for responding. Here are the model numbers:
AC1900= EX7000
AC1200= EX6200
I did factory resets several times with the same result.
Aug 08, 2025Guru - Experienced User
What security mode do you have set on the C4000 ISP router?
First try no security temporarily to see if any of the extenders will connect in the open.
Then Set WPA2 and either TPIK or AES, AES would be preferred.
Set manual channels 1 and 40 on the ISP Router as well.
PurpleNurple9 wrote:Thanks for responding. Here are the model numbers:
AC1900= EX7000
AC1200= EX6200
