dhiggs
Aug 15, 2021Follower
AC1900 Model EX6400 green power light never stops blinking
do any of the other lights blinkng?
Have you tried a factory reset?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Michael197Aspirant
I have also same problem from couple of days but can't find any solution if anyone have solution please reply.
Michael197 did you try the solution I put?
