Gary3935
Aug 11, 2021Tutor
AC1900 refusing some connections
Yesterday my AC1900 WiFi extender started refusing connections to some devices on the 2.4GHz band. I can connect a couple Chromebooks but other devices (cell phones, Wyze cameras, and iPads) will no longer connect at 2.4GHz. iPads and phones will connect on the 5GHz band. This problem just started yesterday, had been working just fine. I updated the router's firmware and cycled power on all devices. Still can't connect devices that had connected just fine at 2.4GHz.
Any ideas what would cause this?
When some devices work while others don't, my first move is to look at the wifi clients rather than the wifi source.
Tried getting the refuseniks to forget the connection and rejoining the wifi?
Before or after this happened?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- Gary3935Tutor
Everything has been working fine on the 2.4GHz band for several years now. It just started refusing connections a couple days ago for connection attempts from about half of my devices that have been connection just fine for years.
After several of my devices would no longer connect on the 2.4GHz band I updated the firmware in the router. No change, some devices will connect, others will not connect.
Disabled the 5GHz band on the router. No change.
On the router setup page there is no ability to reduce the number of clients so I should get 16 on each band. This limit was never reached, just some devices no longer connect at 2.4GHz.
Looks like I have to buy a new WiFi extender.
well, you didn't answer any of the questions asked.
What router is the EX7000 connected to?
Did you setup the extender using wps or using the installation wizard?
