Bslobo's avatar
Bslobo
Ac1900 WiFi extender
purchased the unit. I need to mount to the wall. The unit I had was a dlink 655 router.
Does anyone one have any suggestions on mounting to the wall?  It has no holes for the mounting screws. The unit only has a base mount for a table
  • FURRYe38's avatar
    Build a small wooden shelf on the wall where the R7000 needs to be placed?
    • Bslobo's avatar
      Bslobo
      Thx  I looked on Amazon and got a wall mount bracket.  It slides into the bracket.  WIll let you know  Thank you for the response.
      • FURRYe38's avatar
        Good place to check. I know Amazon has brackets for the Orbi system. Didn't know if they had one for the EX. Let us know how it turns out.
