Arjay1987
Jul 21, 2022Initiate
AC750 EX3700 Password Incorrect Issue
Hi all, seems to be common issue, seeking a legend with a solution! After linking via WPS, I have 2G + 5G EXT networks on my devices. However on multiple devices, always get 'Incorrect Password' when...
Arjay1987
Jul 25, 2022Initiate
Hi plemans , thanks for replying. Do you mean the browser setup via the manual? If so, it doesn't look like I can do that without first having connected to either of the EXT networks (unless i'm mistaken)?
Or is the installation assistant something else that i've not factored? If so, where do I find the details for it?
Jul 25, 2022Guru - Experienced User
You do need to either be connected via wifi or using an ethernet wire to use the installation assistant.
But if you've already used wps, you'd need to factory reset to get back to the defaults to use the installation assistant.
You can factory reset by pushing reset for 7-15 seconds while its powered on.
