tkeehan
Jun 21, 2018Follower
AC750 EX6100 - New Extender Setup recycles back
I have a new EX6100v2 wifi range extender. I have followed all the steps in the Quick Stert guide.
I can access the router with the 2GEXT signal on my laptop but cannot connect my Roku device which is why I bought it.
My Roku device sees both the 2GEXT and the 5GEXTconnect the roku it says cannot connect.
When I connected with the computer I had to do so by pushing the WPS button on the extender as when I tried using the network password
it also would not connect.
What do I try now
1 Reply
- DarrenMSr. NETGEAR Moderator
try to change the SSID and password go to www.mywifiext.net login with admin/password if you haven't changed the login password and try changing the ssid of the network.
DarrenM
