dcleary01
Aug 06, 2025Tutor
AC750 Extender not accepting Wifi router password
Hi,
I just purchased a AC750 wifi extender, I have connected it to the main wifi router via WPS.
The 2G & 5G networks are both visible on devices. But i am unable to connect a device to the extender, It will not accept the main wifi password.
I've logged onto the extender, it stats "Same as existing network password", but that is not working?
Do I need to take a hammer to the netgear device?
Thanks, the extender required an update, addressing a security bug, it now works!
Factory reset the extender and set it up using the installation assistant and NOT WPS.
Try that first.
What router is it?
OK, if i set it to no password, i can connect to the extender from my phone, if i then set it back to either main router password, or even setup a different password, it fails the password on my phone?
