xoccerplaya's avatar
xoccerplaya
AC750 Model EX3700 Connected to internet but can't get back to settings
Recently set up AC750. I went through the set up no problem, created the new extended networks and connected to them. The internet works but now I am unable to get back into its settings via the default website. I've tried other solutions online and through the whole troubleshooting setup but still haven't been able to connect. I want to get back in to set up the fastlane technology.
thx
  • Log into your router and look for its attached devices page (or equivelent for your router).
    It should have the IP address for the extender.
    Use that ip address to connect/manage the device.
  • plemans's avatar
    • xoccerplaya's avatar
      xoccerplaya
      Thank you! I was able to find the address and finally get back into the settings.
      I set up the fastlane but as soon as that set up the extender won't connect to the internet...
      The extended network is created but won't connect to the internet. No lights are on other than the power. Not sure what went wrong
      • plemans's avatar
        You can always factory reset and reinstall as you did before to get it working. push and hold reset for 7-15 seconds while powered on
