RSM52
Nov 28, 2016Tutor
AC750 Range Extender does not work with Ethernet Cable
WIFI on extender working fine. When I plugged in my Win 7 machine it connected momentarily but will no longer connect. Any trouble shooting suggestions. I thought was just plug and play but perhap...
RSM52
Nov 29, 2016Tutor
An update - after speaking with technical support they informed me that only gaming consoles can use the ethernet port on the Extender. This makes no sense and defeats the purpose of having a remote ethernet port. I am hoping that a clever community member has found a workaround to this. There must be a way to get the extender talking to a Win 7 desktop?!? Help would be appreciated.
- DarrenMDec 01, 2016Sr. NETGEAR Moderator
Hello RSM52
It should work on any ethernet device do you have the latest firmware? And when the connection goes out does it show up as a red x on the connection like no Ethernet is connected or does it just not connect to the internet anymore?DarrenM
- RSM52Dec 01, 2016Tutor
Thanks for the prompt reply. I ended up buying a wireless adapter for 20 bucks which connects without a problem. Trying to get the computer working with an Ethernet cable seemed fraught with frustration.
