RSM52
Nov 28, 2016Tutor
AC750 Range Extender does not work with Ethernet Cable
WIFI on extender working fine. When I plugged in my Win 7 machine it connected momentarily but will no longer connect. Any trouble shooting suggestions. I thought was just plug and play but perhap...
DarrenM
Dec 01, 2016Sr. NETGEAR Moderator
Hello RSM52
It should work on any ethernet device do you have the latest firmware? And when the connection goes out does it show up as a red x on the connection like no Ethernet is connected or does it just not connect to the internet anymore?
DarrenM
RSM52
Dec 01, 2016Tutor
Thanks for the prompt reply. I ended up buying a wireless adapter for 20 bucks which connects without a problem. Trying to get the computer working with an Ethernet cable seemed fraught with frustration.
