Tilley61
May 10, 2016Follower
AC750 Wi-Fi range extender - attaching cloud camera
I've purchased an AC750 to improve the wifi in an area where I need to run a cloud camera. The camera is currently attached to the main router but keeps dropping out hence the need for an improved s...
TheEther
May 10, 2016Guru
You can use WPS to connect the camera, but the procedure is different. Instead of using the physical button the extender, you have to log into the extender via www.mywifiext.net, open the Menu and select Do More > Connect Devices (WPS). There, you will see a WPS button. Click on this button. You will have 2 minutes to push the WPS button on the camera.
