Reggae
Feb 20, 2016Aspirant
AC750 Wi-Fi range extender
My WiFi extender works well once connected, but every day I have to cycle power to get it to connect to my device. It asks me for my WEP password, but won't take it when I enter it. Once I cycle powe...
- Feb 25, 2016
DarrenM,
Thanks for all the help. As soon as I get my adaptor, I'll reload the firmware and do setup again.
Reggae
DarrenM
Feb 23, 2016Sr. NETGEAR Moderator
Hello Reggae
Is the extender a littler to far away from the router and it drops signal? If not have you tried to factory reset he extender and go threw setup again.
DarrenM
- ReggaeFeb 23, 2016Aspirant
Hi DarrenM,
The extender is in range per the indicators, and does not drop the signal. Works great when connected. It just requires a power cycle for me to connect every day or two. I setup the Wifi extender via a Wifi connection. Net gear said I should do setup again using a hard wire Ethernet connection. Apparently the wifi connection is prone to interference that can corrupt the firmware. I guess I'll have to set up again using a hard wire connection to the extender per your and netgear support advice. Thanks for the reply.
- DarrenMFeb 24, 2016Sr. NETGEAR Moderator
Reggae
Let me know if that resolves the issue or not.
DarrenM
- ReggaeFeb 24, 2016Aspirant
Darrell M,
I have a Macbook pro laptop. once I get a thunderbolt to ethernet adaptor and shut off my wifi connection at my laptop, do i just do the ethernet connection between the laptop and the extender, or do i need to connect through my router (e.g. laptop to router, and router to extender)?
