Reggae
Feb 20, 2016Aspirant
AC750 Wi-Fi range extender
My WiFi extender works well once connected, but every day I have to cycle power to get it to connect to my device. It asks me for my WEP password, but won't take it when I enter it. Once I cycle powe...
- Feb 25, 2016
DarrenM,
Thanks for all the help. As soon as I get my adaptor, I'll reload the firmware and do setup again.
Reggae
Reggae
Feb 23, 2016Aspirant
Hi DarrenM,
The extender is in range per the indicators, and does not drop the signal. Works great when connected. It just requires a power cycle for me to connect every day or two. I setup the Wifi extender via a Wifi connection. Net gear said I should do setup again using a hard wire Ethernet connection. Apparently the wifi connection is prone to interference that can corrupt the firmware. I guess I'll have to set up again using a hard wire connection to the extender per your and netgear support advice. Thanks for the reply.
DarrenM
Feb 24, 2016Sr. NETGEAR Moderator
Reggae
Let me know if that resolves the issue or not.
DarrenM
- ReggaeFeb 24, 2016Aspirant
Darrell M,
I have a Macbook pro laptop. once I get a thunderbolt to ethernet adaptor and shut off my wifi connection at my laptop, do i just do the ethernet connection between the laptop and the extender, or do i need to connect through my router (e.g. laptop to router, and router to extender)?
