Reggae
Feb 20, 2016Aspirant
AC750 Wi-Fi range extender
My WiFi extender works well once connected, but every day I have to cycle power to get it to connect to my device. It asks me for my WEP password, but won't take it when I enter it. Once I cycle powe...
- Feb 26, 2016
DarrenM,
Thanks for all the help. As soon as I get my adaptor, I'll reload the firmware and do setup again.
Reggae
DarrenM
Feb 25, 2016Sr. NETGEAR Moderator
Reggae
To setup the extender you would want to plug directly into it.
DarrenM
Reggae
Feb 26, 2016Aspirant
DarrenM,
Reggae
- ReggaeMar 03, 2016Aspirant
DarrenM,
Just reinstalled the firmware recently using a hard wired ethernet connection, the extender works well with all devices now. I also found out that there is a compatibility issue running netgear's genie app for my MAC running OSX El Capitan. I closed the app prior to reflashing the firmware, so not sure if the reflash of the firmware, or shutting down the genie app fixed my issue. I was advised to delete the genie app from my computer until apple and netgear resolve the issue. Thanks for all your help through my issue.
- DarrenMMar 03, 2016Sr. NETGEAR Moderator
Reggae
Thanks for that tip if that was what caused the issue.
DarrenM
