Northflboy
Mar 30, 2018Aspirant
Ac750 WiFi EX6100v2 range extender
Set up went fine. Instructions say to enter the same password you do for your home router. When I do that, it won’t connect. Any advice?
jvasanth1984
Apr 01, 2018Virtuoso
Hi Northflboy,
Please check the password of your router as it is case sensitive and your extender can connect to it only if you enter the correct password. If you are entering the correct password and if you still encounter the same issue, please skip the setup and check for firmware upgrade if any, do manual update and try running the setup again.
Northflboy
Apr 02, 2018Aspirant
Password was correct. Still will not connect
- jvasanth1984Apr 03, 2018Virtuoso
Hi Northflboy,
Did you skipped the setup and tried looking for firmware upgrade if any?
- NorthflboyApr 05, 2018AspirantNo I didn’t do that.. i will try that thanks u
- jvasanth1984Apr 05, 2018Virtuoso
Hi Northflboy,
Let me know if that worked.
