Northflboy
Mar 30, 2018Aspirant
Ac750 WiFi EX6100v2 range extender
Set up went fine. Instructions say to enter the same password you do for your home router. When I do that, it won’t connect. Any advice?
Northflboy
Apr 02, 2018Aspirant
Password was correct. Still will not connect
jvasanth1984
Apr 03, 2018Virtuoso
Hi Northflboy,
Did you skipped the setup and tried looking for firmware upgrade if any?
- NorthflboyApr 05, 2018AspirantNo I didn’t do that.. i will try that thanks u
- jvasanth1984Apr 05, 2018Virtuoso
Hi Northflboy,
Let me know if that worked.
