dpg0217
Sep 09, 2020Aspirant
AC750 Wifi Range Extender EX3700 not connecting to AC1900 Smart Wifirouter
My AC1900 Smart WiFi Router and my Lenovo ideapad 310 cannot find the AC750 WiFi Range Extender EX3700. The EX37000 WPS LED will not stay on following the instructions on page 7 of the manual. I performed the actions twice.
The ideapad laptop does not find the NETGEAR_EXT so I cannot follow the instructions on page 9.
I have already pressed the factory reset button.
Network profile is Public
Security Type is WPA2-Personal
Network Band is 2.4 GHz
When you push reset, are you pushing and holding for 7-15 seconds while its powered on?
What are the led's on the extender doing?
- dpg0217Aspirant
The Power LED turns orange and blinks while pressing reset, goes off after I stop pressing, goes to solid orange, then goes to green.
have you tried hardwiring into it for setup?
just disable the wifi on whatever device you connect to it so it doesn't default back to wifi
