FCB123's avatar
FCB123
Follower
Mar 05, 2018
AC750 WiFi Range Extender Mod. EX3700
Would I be able to purchase another one of these extenders but plug it into the third floor to get better WiFi. I tried plugging this one extender to the middle floor where the WiFi is located but the signals weak for both our Xbox’s on the first and third floor. After I installed it downstairs by one Xbox it worked great, but of course no signal upstairs. Will a second extended plugged in on the third floor fix the issue with the connection?
1 Reply
  • Hi FCB123,
                           You may extend the signal from first extender using second, but there will a dip in performance.
