jjb4521
Nov 16, 2018Aspirant
Access Point configuration issue
After restoring the factory defaults on my WN2500RP, I followed the instructions for setting up as an access point. All seems to go well until I power it down after I finish configuring it and power ...
Nov 16, 2018Guru - Experienced User
Can you connect to the router's wifi from that new room (with your phone or some other wifi client)?
- jjb4521Nov 16, 2018AspirantI can connect to the access point via wifi, but the access point has no connection to the internet
- schumakuNov 16, 2018Guru - Experienced User
Aehm ... aware a network cable is required to connect the AP to the router? It's an access point, not a extender or repeater.
- jjb4521Nov 16, 2018AspirantYes, I am... I’m using a pair of Netgear powerline adapters to get back to my router ... but even when I configured it using a cable to the router , I still had the same issue... the power light stayed amber
