jermlh
Jan 14, 2018Aspirant
Access Point to Arris Router
I have AT&T fiber with a Arris BGW 210-7000 Router. I have been using my EX 7000 Range Extender as an acces point. I went away for a week and when I returned I could no longer get a connection using ...
jermlh
Jan 18, 2018Aspirant
Thanks for the suggestion. I tried your suggestion but still could not get internet although i had a "connection."
jvasanth1984
Jan 19, 2018Virtuoso
Hi jermlh,
Can you check if you bypass the extender which is AP mode and internet works through the same ethernet cord which was providing connection to it?
- jermlhJan 21, 2018Aspirant
I finally did check the connection and discovered that the ethernet cable under the house had been cut - which was the source of the problem. Should have checked the cable first but stupidly didn't. Thanks so much for suggestion. I have ordered new cable and hopefully that will resolve problem.
- jvasanth1984Jan 31, 2018Virtuoso
Hi jermlh,
Hope you changed the cable and it resolved your problem.
