Jan64
Jun 23, 2016Aspirant
Accessing an IP camera behind NETGEAR WN2500 extender
I have installed a Foscam IP camera on my SAGEM wifi network and I have successfully arranged port forwarding etc to access the camera from the outside. Now I have also installed a Netgear WN2500 ex...
Jan64
Jun 25, 2016Aspirant
Thanks for your contribution and the message that the extender should be transparent as far as port forwarding is concerned. I also do not see any opportunity within the extender to modify this. I did already install a fixed IP adress for the camera, so that is certainlly not the problem. In the mean time I did input the virtual mac address into the modem, so as to link the fixed IP adress to the camera, but that trial is certainly not working.
As said before, as soon as I link the camera to the wifi network sent out by the SAGEM modem, then I can approach the camera successfully.
Does anyone have any suggestion. ? I have scanned the discussion on similar topics,, but from that i have not seen applicable solutions.
TheEther
Jun 26, 2016Guru
Do you have MAC address access control enabled on the SAGEM modem? If you do and the modem failed to accept the virtual MAC address, then you need to resolve that before port forwarding will work. Try temporarily disabling MAC address access control.
