Daali
Jan 01, 2011Aspirant
Accessing WG302 via http since the year changed?
I am getting a "Self Certificate" page since this morning accessing my WG302's.
Any insight?
Any insight?
- phancoxAspirant
smegger wrote: I have experienced the same problem, with my WG302, as Daali today. Also I managed to log in as normal by Factory defaulting the AP but then am unable to login again after reconfiguring, same displays as Daalis.
Same problem here.
Resetting to factory defaults works until the WG302 is configured for internet access. At that point I'm guessing it accesses NTP server and updates its internal clock. After that occurs, it knows the current certificate is no longer valid and refuses to use it.
Guessing that the screen we now see after login is supposed to allow update of certificate but doesn't appear to be functional.
SSH access works but don't know how to fix the certificate.
Prompt attention by Netgear would be appreciated. I've contacted technical support help desk but they were unaware of the problem. This was only an hour ago so they weren't aware of this forum thread. I've sent them a link to it now. - jmizoguchiVirtuosoFigure this is going to be for all wgxx owners do not post anymore.....1 use my.netgear.com and open the case immediately!!!!!!:):)
- qrsd_techAspirantExact same problem here!!!!! What is netgear doing about it? I need this resolved! Anyone know any more?
- jmizoguchiVirtuosoRead what is been told to do!!!!!!!!!
- jmizoguchiVirtuosodo not post anymore.....1
use my.netgear.com and open the case immediately!!!!!!! - qrsd_techAspirantOk, I went to my.netgear.com. I registered, and I looked everywhere I think I should, but it sends me back to this forum everytime. Am I missing something? All I'm looking for is the answer. Thanks.
- jmizoguchiVirtuosoopen the case. you can send your issues.
forum is NOT support. go back again... over 9x some percent has not issue opening the case...... :) - jmizoguchiVirtuoso
ONLINE TECHNICAL SUBMISSION
took 2sec to see it..:) - DaaliAspirantIs anyone getting anywhere? I am still talking via email to tech support. Just curious if anyone else has had any luck.
- jmizoguchiVirtuosoThis seems firmware issues . Does not look like to be any fixes without new firmware
