Daali's avatar
Daali
Accessing WG302 via http since the year changed?
I am getting a "Self Certificate" page since this morning accessing my WG302's.
Any insight?
  • thanks guess its off to the store again should have just purchased a new unit cost is going to be about 160.00 by the time u add what i paid for the 2 302 cable null modem and adapters will let you know what happens next. was able to do a tftp tried to reflash the unit said it took it but still can not use gui to get in. this is the last shot before they go in the trash.
    Thanks again
    Mark
  • Well got the null moden I can ser into it as well as ssh into it but no web ui.
    it looks like it takes a tftp to chenge frimware but when i check to see if it took the new frimware it still has the old one. I even tried to flash it with dd-wrt but no go how can i config this unit any ideas noobe to the ssh and ser have been doing all mine other config,s with the gui ui.
    Thanks
    Mark
  • Anyone I was able to put dd-wrt on unit but have to pay for it, I head as how most of the users here can get back into the units by doing a factory reset, I have not been able to do this. opemwrt is a bit to much for me. can anyone help get me to where i can log in with the web ui. ? please
    thanks
    Mark
  • OK, so if I understand this correctly, if I have a v2 WAG302/WG302 I must go into the web GUI before the certificate expires and disable the NTP server setting. Is this all that is needed? For the v1 version, I must do a factory reset and then access the web GUI, without internet access, and do the same?
  • I have solved the issue in this way:
    I use endian as a firewall, i blocked the port 123 (ntp port) to this AP and rebooted it...now everything works!
