captshaq's avatar
captshaq
ACL on Router and Extender?
I have ACL on my router (Linksys) and it's working well. Now I added the NG 2500RP extender. Do I need to add each end-point to the router's ACL itself, or is it enough to have the extender's MAC addresses listed on the router's ACL?
Also, can I (or should I) activate the extender's own ACL and if that's the case - add each end-point MAC address to both ACLs?
Thanks!
  • Did you already installed?
    ACL is preference but again it seems extender and ACL can conflict
    This needs to tested and see ACL will work or not
    Yes, already installed. The issue is that with my home network being extended - I have all the more reason to have an ACL. If the extender doesn't do it I'm thinking of wiring a separate access point from one of my router's physical ports. It may be less complicated that way.
  • If you can wire it that is far most choice to begin
    Extender will reduce performance for wifi device connect to extender
