robm79's avatar
robm79
Add Readyshare access permission/password
Installed a USB hard disk on my EX6200 (which doesn't appear in the drop-down list of products, Netgear!)   Is there any way to set different access permissions and passwords for different users? A...
  • ElaineM's avatar
    Apr 06, 2016
    Hi robm79
    Welcome to the community!
    There's no way to set the permission by users.
    Another approach you may want to do is to create folders on your USB drive and set permissions on those folders.
    You can specify the exact folder location that wanted to share within your network and set passwords on it.
