filmmakerguy's avatar
filmmakerguy
Follower
Sep 22, 2016
Adding a WN3500RP to AT&T U-Verse...ugh! (ATT ATandT AT and T)
So...after a LOT of time trying to get my shiny new extender (the WN3500RP) to connect to my AT&T U-Verse network...turns out the problem was that the WPS feature (Wireless Protection Setup) was NOT EVEN TURNED ON!
I don't know if this is a system default, or the way the tech set it up, but it is touted as a great "feature" of the router, so I have no idea why this would not have been enabled when the tech-guy set it up.
To change the setup of your router:
-type "192.168.1.254" into your web browser to manage the router.
-go to "Home Network" tab
-go to "Wireless" sub-tab
-in the Wireless configuration, turn ON the WPS option (mine was off!)
-SAVE the changes!
(full disclosure: I have no idea what the PIN feature accomplishes, but I didn't mess with that.)
-I restarted the router for good measure...then sure enough...I was able to connect the WN3500RP (as well as an almost-discarded printer!) just as easily as the normal WPS feature is supposed to be! (pressing the WPS button on the device, then on the router, and in a few minutes, they're connected.)
Anywho, just wanted to share my experience/solution/nightmare so anyone who searches for a similar problem might be helped...and saved from jogging around the house hitting the same buttons over, and over, and over, and over...
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello filmmakerguy
    Thank you for sharing this info.
    DarrenM
  • you lost me at type into web browser.....
    what web browser on what devise?  url?
    Ive been trying to connect my range extender for two days and the netgear genie keeps sending me to the same page to start over no matter how carefully i follow instructions and type in numbers and passwords. every time I hit continue it takes me back to the beginning. aaaaargh!
