GleasonFan
Aug 30, 2018Aspirant
Adding WN3000RPv2 to Spectrum Time Warner wireless
We recently switched from ATT to Sepctrum at work for internet and telephone service. (FYI - We're saving about $60 a month for 10X faster speed.) There is a single dead zone in our lower level with ...
GleasonFan
Sep 07, 2018Aspirant
We placed the extender under a table that seldom if ever is moved. When I check the signal using my Android phone, the intened network does not appear but the old one is blowing off the scale in signal strenght. Apparently the extender works great but is still named for the previous WiFi and is locked. Mywifiext.net says I'm not connected. Suggestions?
Seanson
Feb 20, 2019Aspirant
Did you happen to get this figured out? I'm a Spectrum user and ran across your post. I'm having the same issue with a Linksys range extender. Connects fine to the router, produces a wireless network, connect to the network and no available internet.
- GleasonFanFeb 22, 2019Aspirant
No. Spectrum's advice was to reboot the router which is kind of hard to do since we need the connection 24/7.
- SeansonFeb 22, 2019AspirantI'm pretty confident that rebooting the router wont help. I'll try it in a bit though and let you know if it does anything. Thanks for your response!
