JasperLangham's avatar
Mar 10, 2017
admin password wont change when i reset
When I reset My Extender I Go To Change The Security Type And I Have to do the admin and password part but the password isnt password, Please Help!?!
  • Hello JasperLangham
    When factory resetting the unit it should be password make sure you hold the reset button for atleast 10 seconds.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello JasperLangham
    DarrenM
