Ecanilla's avatar
Aug 20, 2021
Advice needed on functionality on RAXE500 and AX8 (RAX80)
Hello Community,
hope you are well well and safe.
Would need your advice on either RAXE500 and AX8 (RAX80) which I'm currently "eying" as a replacement for my current setup.
I've currently have a WiFi router in the house and a "satellite" in a Mesh configuration.
The "satellite" is in our garden (approx. 150feet from router) in a separate workshop and hooked up via CAT6 cable (Ethernet backhaul) to the router in the house.
It all works seamlessly and I'd rather not want to lose this kind of setup with getting either of the mentioned Netgears.
So, long story short, is this kind of setup possible with either of the mentioned Netgear choices?
Many thanks for your input and help
all the best
Alex
  • heya mate,
    thanks again :).
    Its not the I'm "eyeing" the latest/greatest ... but ... if I'm replacing a 5 year old system ... I thought it won't do any harm going for "future proofing" (at least somewhat ;) )
    Thanks again mate
    all the best
