Tinkerbell666
Jan 06, 2026Aspirant
Advice needed please
Hi all. I'm looking for some help please. I currently have Zzoomm fibre and want to change to a netgear nighthawk wiffi 7 router. I also need 2 mesh extenders/boosters. I'm nit sure what would suit...
Jan 06, 2026Guru - Experienced User
Tinkerbell666 wrote:I also need 2 mesh extenders/boosters. I'm not sure what would suite. I need better reception around my home. My house is about 175 years old.
Can you give a bit more detail on the house - number of floors, approx square feet (or square meters) per floor. Maybe also info on any fireplaces (as the chimneys can block wifi).
Are the interior walls all wooden construction?
Do you have any existing ethernet or coax cabling installed? If so, what floors does that reach?
