markgrant
Apr 18, 2018Aspirant
All lights GREEN but no _EXT network appears
Mac OSX 10.13.4 iOS 11.3 - 6th gen iPad, iPhone 6 WPS set-up went smoothly and lights are all GREEN on the extender, except the DEVICE light which is nothing, neither green nor red. And no _EXT ...
- Apr 24, 2018
Have you tried to factory reset the unit by holding the reset button for 10+ seconds then try to set up the extender again? Then try to give it a different SSID when in the setup process.
DarrenM
DarrenM
Apr 20, 2018Sr. NETGEAR Moderator
Try to connect to the extender again VIA www.mywifiext.net login and try changing the SSID see if that shows up to your devices.
DarrenM
- markgrantApr 20, 2018Aspirant
Did that (see bove). mywifiext.net gives me:
"You are not connected to your extender's WiFi network."
Which is the whole problem.
- stevekjaApr 23, 2018Aspirant
I have the same problem trying to connect
to BT smart Hub... I have given up with this crap
- DarrenMApr 24, 2018Sr. NETGEAR Moderator
DarrenM
