markgrant's avatar
markgrant
All lights GREEN but no _EXT network appears
Mac OSX 10.13.4 iOS 11.3 - 6th gen iPad, iPhone 6   WPS set-up went smoothly and lights are all GREEN on the extender, except the DEVICE light which is nothing, neither green nor red. And no _EXT ...
  • DarrenM's avatar
    DarrenM
    Apr 24, 2018
    Have you tried to factory reset the unit by holding the reset button for 10+ seconds then try to set up the extender again? Then try to give it a different SSID when in the setup process.
    DarrenM
