markgrant
Apr 18, 2018Aspirant
All lights GREEN but no _EXT network appears
Mac OSX 10.13.4 iOS 11.3 - 6th gen iPad, iPhone 6 WPS set-up went smoothly and lights are all GREEN on the extender, except the DEVICE light which is nothing, neither green nor red. And no _EXT ...
- Apr 24, 2018
Have you tried to factory reset the unit by holding the reset button for 10+ seconds then try to set up the extender again? Then try to give it a different SSID when in the setup process.
DarrenM
markgrant
Apr 20, 2018Aspirant
Did that (see bove). mywifiext.net gives me:
"You are not connected to your extender's WiFi network."
Which is the whole problem.
DarrenM
Apr 24, 2018Sr. NETGEAR Moderator
DarrenM
