alaric
Oct 18, 2015Aspirant
Android connection to new PC running Windows 10
My Netgear WN3000RP-V2 has worked well for a year, taking a signal from a WNR2000-V3 router and relaying to an Android tablet. Last week I installed a new PC running Windows 10. The tablet works fr...
alaric
Oct 28, 2015Aspirant
Hollo nhann,
The set up is;
Talktalk ---(wire)--- D-link router
Talktalk----(wire)---- WNR2000v3 router ---(RADIO? NO WIRE)---WN3000RPv2 extender - - - (WiFi) - - - Android tablet
nhann
Oct 29, 2015NETGEAR Employee Retired
Hi alaric,
Try disconnecting the D-link, then leave the WNR2000v3 connected.
Are you now able to reach the internet?
- alaricOct 29, 2015Aspirant
Taking out the D_link and using the netgear as the modem does not allow my PC to connect with the internet, I have reinstated the D_link. I can connect my android tablet to the D_link, but not to the netgear router or extender.
Please tell me what I need to do to get them to work.
- nhannOct 30, 2015NETGEAR Employee Retired
Hi alaric,
The NETGEAR WNR2000v3 cannot be used as a modem.
Try connecting the D-link to your TalkTalk modem, then connect your WNR2000v3 (set to Access Point) to the D-link router.
